el tipo de seccion en incorrecto
9 años 6 meses antes - 9 años 6 meses antes #1286 por DIANA BERENICE LONGORIA DE LEON
Hola que tal, podran ayudarme con esto, me aparece solo en un presupuesto y solo cuando quiero imprimir el presupuesto, pero no tengo problema al imprimir el programa...Gracias!!!!
System.Exception: El tipo de sección es incorrecto at DevExpress.XtraReports.UI.BandCollection.OnInsert(Int32 index, Object value) at System.Collections.CollectionBase.System.Collections.IList.Add(Object value) at DevExpress.XtraReports.UI.XRControlCollection.Add(XRControl child) at EcoSoft.Commons.Services.Reporting.ApplicationReportingService.Initialize_Report(XtraReport report, String titulo, Boolean desglose) at EcoSoft.Commons.Services.Reporting.ApplicationReportingService.ShowPreview(Object dataSource, String reportName, ControlPresentation controlPresentation, Boolean desglose) at Opus.Modulo1.Application.Services.OpcionesReporteService.vYBhZHEgxew5nLeBLeWO(Object , Object , Object , Object , Boolean ) at Opus.Modulo1.Application.Services.OpcionesReporteService.ObtenerDatosVistaReporte(ApplicationModel appModel, Boolean preview) at Opus.Modulo1.Application.Modulo1CommandHandler.VwL0eab6isb067lN5vYl(Object , Object , Boolean preview) at Opus.Modulo1.Application.Modulo1CommandHandler.IaBIMdA9D7G(Boolean ) at Opus.Modulo1.Application.Modulo1CommandHandler.GawIMKLCL4R(Command ) at EcoSoft.Windows.Commands.BaseCommandHandler.Execute(Command command) at EcoSoft.Windows.Commands.CommandBaseController.ExecuteOnCommandHandler(Command command, ICommandHandler hostCommandHandler) at EcoSoft.Windows.Commands.CommandBaseController.ExecuteOnCommandHandler(Command command) at Opus.Modulo1.Application.Modulo1CommandInitializer.t5BOh1b6lhQ7WU6efvG8(Object ) at Opus.Modulo1.Application.Modulo1CommandInitializer.z54IMqbgWpN(Object , CommandEventArgs ) at EcoSoft.Windows.Commands.Command.OnExecute(CommandEventArgs e) at EcoSoft.Windows.Commands.Command.DoExecute() at EcoSoft.Windows.Commands.Executors.DxBarItemCommandExecutor.button_ItemClick(Object sender, ItemClickEventArgs e) at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link) at DevExpress.XtraBars.BarButtonItem.OnClick(BarItemLink link) at DevExpress.XtraBars.BarItemLink.OnLinkClick() at DevExpress.XtraBars.BarButtonItemLink.OnLinkClick() at DevExpress.XtraBars.BarItemLink.OnLinkAction(BarLinkAction action, Object actionArgs) at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs) at DevExpress.XtraBars.BarItemLink.OnLinkActionCore(BarLinkAction action, Object actionArgs) at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link) at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link) at DevExpress.XtraBars.Controls.CustomLinksControl.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at DevExpress.XtraBars.Controls.CustomControl.WndProc(Message& msg) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Última Edición: 9 años 6 meses antes por Arq. Everardo López P..
9 años 6 meses antes #1287 por Arq. Everardo López P.
Hola Diana. Tu versión es ¿OPUS 16?
9 años 6 meses antes - 9 años 6 meses antes #1288 por DIANA BERENICE LONGORIA DE LEON
si!!! opus 16.....ya solucione eso...hice una copia del presupuesto y se quito el problema...ahora quiero imprimir los costos horarios de la maquinaria y me apaeece...
System.InvalidOperationException: Sequence contains no elements at System.Linq.Enumerable.First[TSource](IEnumerable`1 source) at DevExpress.XtraEditors.Preview.PrintEditorController.LoadForm() at DevExpress.XtraEditors.Preview.PrintEditorForm.PrintEditorForm_Load(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at DevExpress.XtraEditors.XtraForm.WndProc(Message& msg) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
9 años 6 meses antes #1289 por Arq. Everardo López P.
Adjuntame la obra de OPUS 16 y así reviso que inconsistencia tiene. Aparentemente no hay datos en alguno de los campos requeridos para el costo horario.
El siguiente usuario dijo gracias: DIANA BERENICE LONGORIA DE LEON
Tiempo de carga de la página: 0.256 segundos
