Problema con la función ajustar presupuesto
10 años 9 meses antes - 10 años 9 meses antes #1095 por arturo
Buenos días cuando quiero utilizar el comando de ajustar presupuesto me aparece el siguiente error:
OPUS ha generado la siguiente excepción
Index was outside the bounds of the array.
System.IndexOutOfRangeException: Index was outside the bounds of the array. at Opus.Modulo1.Application.Services.AjustarPrecioServiceController.AjustarPrecioProyecto(IList`1 dataRows, Boolean desdeHP) at Opus.Modulo1.Application.Views.HojaPresupuestoViewController.EjecutaAjustarPreciosCommand(Command command) at EcoSoft.Windows.Commands.BaseCommandHandler.Execute(Command command) at EcoSoft.Windows.Commands.CommandBaseController.ExecuteOnCommandHandler(Command command, ICommandHandler hostCommandHandler) at EcoSoft.Windows.Commands.CommandBaseController.ExecuteOnCommandHandler(Command command) at Opus.Modulo1.Application.Modulo1CommandInitializer.CommandExecute(Object sender, CommandEventArgs e) at EcoSoft.Windows.Commands.Command.OnExecute(CommandEventArgs e) at EcoSoft.Windows.Commands.Command.DoExecute() at EcoSoft.Windows.Commands.Executors.DxBarItemCommandExecutor.button_ItemClick(Object sender, ItemClickEventArgs e) at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link) at DevExpress.XtraBars.BarBaseButtonItem.OnClick(BarItemLink link) at DevExpress.XtraBars.BarItemLink.OnLinkClick() at DevExpress.XtraBars.BarItemLink.OnLinkAction(BarLinkAction action, Object actionArgs) at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs) at DevExpress.XtraBars.BarItemLink.OnLinkActionCore(BarLinkAction action, Object actionArgs) at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link) at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link) at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnUnPressItem(DXMouseEventArgs e, RibbonHitInfo hitInfo) at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnUnPress(DXMouseEventArgs e, RibbonHitInfo hitInfo) at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnMouseUp(DXMouseEventArgs e) at DevExpress.XtraBars.Ribbon.Handler.RibbonHandler.OnMouseUp(DXMouseEventArgs e) at DevExpress.XtraBars.Ribbon.RibbonControl.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at DevExpress.Utils.Controls.ControlBase.WndProc(Message& m) at DevExpress.XtraBars.Ribbon.RibbonControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Última Edición: 10 años 9 meses antes por Arq. Everardo López P..
10 años 9 meses antes #1098 por Arq. Everardo López P.
Pienso que ha estas alturas te abras dado cuenta que este error se presenta cuando el presupuesto o el precio unitario que deseas ajustar no ha sido recalculado.
Antes de que corras este proceso recalcula tu obra.
Estoy seguro que en nuevas actualizaciones de OPUS este detalle se ha solucionado. Actualizate o bien sigue las recomendaciones que te he planteado.
Dinos como te fue.
Tiempo de carga de la página: 0.138 segundos
